airassaultbob
Jun 02, 2021Follower
RAX70 smart connect
When in settings and enabling the smart connect feature, all appliances on the wifi disconnect and will not re-connect even when manually attempting to do so
andersfriden
Jun 19, 2021Aspirant
hello
I'm happy to use smart connect. However, how can I force the router to go above 1200 mb/s? my laptop has a AX201 wifi card, and it can't connect to router beyond this limit (with my previous router Asus RT-AX88U, I could reach 2000+)
Razor512
Jun 20, 2021Prodigy
If that is on the 5GHz band, make sure the mode is set to "Up to 4800Mbps" otherrwise your client devices will connect at 1200Mbps (max PHY rate for a 2 stream WiFi device in that mode (80 MHz channel width).
- Razor512Jun 20, 2021Prodigy
Also, your router offers 3 WiFi radios. One of the radios tops out at 1.2Gbps, and the other tops out at 4.8Gbps.
Make sure you are connecting to the faster radio. If smart connect is pushing you to the slower radio, then disable smart connect and give the 1.2Gbps radio a different SSID.
Usually the main benefit from this is to improve efficiency. For example, many 802.11ac clients top out at 80MHz channel width, and while newer radios that do AX and older standards at the same time have made major improvements in airtime sharing, there is still overhead when dealing with a mixed network, thus it is faster to put all 802.11ac devices on the 1.2Gbps radio, and the ax clients on the 4.8Gbps radio.
- andersfridenJun 21, 2021Aspirant
Unchecked:
my laptop (Asus Zenbook with AX201 wifi):
my Samsung Galaxy S20 FE 5G:
ok, I've switched back to smart connect, and my laptop is connected to the routeur on a 2400 mbps connection speed. BUT now I'm confronted to the same problem which made me buy this Netgear routeur and sell the old one (Asus): on startup, the laptop will connect to the routeur (strong signal, 2400 mbps), but no internet. Onedrive won't log in, Speedtest won't work, Google Chrome won't load a single page. I need to click on the routeur connection (Netgear80 in my case), disconnect, then reconnect. Only then I will have Internet. The problem probably comes from the laptop, more precisely from the wifi 6 card.
