airassaultbob
Jun 02, 2021Follower
RAX70 smart connect
When in settings and enabling the smart connect feature, all appliances on the wifi disconnect and will not re-connect even when manually attempting to do so
VintheValley
Dec 08, 2021Aspirant
Mine just started doing this. Finally realised it was the "smart" connect. When it is enabled wifi stops broadcasting. Turn it off & everything connects. Only had the RAX70 a month or so, new firmware, reboot, checked wires etc etc.
Have you found an answer or are you just not using it?
