雪夜星辰
Oct 07, 2021Star
RAX70 update with 1..0.5.108 firmware always reboot automaticly
I update my RAX70 nighthawk Wifi6 router to the latest firmware 1.0.5.108, but after one or two days, it will be automaticly reboot by itself, I try to Reset equipment and reset all parameter, but th...
- Oct 08, 2021
Thanks for posting!
Glad a downgrade fixed the issue.
Hopefully a mod or engineer sees this so they can be aware of the issue.
雪夜星辰
Oct 25, 2021Star
Today the new version firmware has been realeased, not sure if this has been fixed the issue, will test during next days
https://kb.netgear.com/000064287/RAX70-Firmware-Version-1-0-10-110?language=en_US
Oct 26, 2021Guru - Experienced User
Let us know what you find out.
- 雪夜星辰Oct 26, 2021Star
Will do
- 雪夜星辰Oct 28, 2021Star
After three days continu test, this new version firmware has fixed the issue perfectly, and also provide stable connection with low delay time.
- plemansOct 29, 2021Guru - Experienced User
Glad its up and working well for you!
- FURRYe38Oct 29, 2021Guru - Experienced User
Enjoy. 📡
- 雪夜星辰Oct 31, 2021Star
Thanks for the guid, appreciate for you immediately action to fix this problem, have a nice day!
