F8Crusader's avatar
F8Crusader
RAX70 USB port
The router doesn't recognize my printer on the USB Port.
  • michaelkenward's avatar
    Dec 12, 2020
    Impossible to tell what might be happening given so little information.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    A quick search suggests that your device does not support USB printers.
    You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
    Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
