F8Crusader
Dec 11, 2020Aspirant
RAX70 USB port
The router doesn't recognize my printer on the USB Port.
- Dec 12, 2020
Impossible to tell what might be happening given so little information.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
A quick search suggests that your device does not support USB printers.You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
michaelkenward
Dec 12, 2020Guru - Experienced User
Support | NETGEAR
F8Crusader
Dec 19, 2020Aspirant
That answered my question. 4+ hours with Netgear support answered nothing. They couldn't figure it out. Replaced the router as they discovered the reset button didn't work. But no answers. A few days later, one of their support agents looked at my problem and promptly emailed that mt router USB port didn't support printers.
Thanks
