KevW
Apr 06, 2021Initiate
RAX70 vs RAX80
Hi, Im trying to pick between these 2 routers, any advice would be great! I have a 2,500 size home with 3 gamers and we stream all our TV viewing. The main difference I can see is the RAX70 has...
KevW
I have about 50 devices approx.
The price difference between the two is only £20.
I also notice the netgear gaming x1000 router has the same processor as the RAX70.
Apr 06, 2021Guru - Experienced User
I've never used either one so I can't attest to either's prowress.
I've used the CAX80 that would be similar to the RAX80 and it worked great.
But unsure of if the triband would have any benefit over the dual band.
I've also got a RAX200 but thats a triband with quite a bit more grunt than the RAX70 so its not much of a comparison.
I'd probably try the triband and see how it works. But thats just because I've liked my triband setups.
