xSigoff
Jan 08, 2022Aspirant
rax70 will not allow custom port
I cannot connect by remote desktop on my local gigabitcopper lan. no ports are visible locally, I cannot ping locally. How do I open up all ports on the local lan? I tried adding 3389 as as a custom...
Jan 08, 2022Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
