xSigoff
Jan 08, 2022Aspirant
rax70 will not allow custom port
I cannot connect by remote desktop on my local gigabitcopper lan. no ports are visible locally, I cannot ping locally. How do I open up all ports on the local lan? I tried adding 3389 as as a custom...
Jan 10, 2022Guru - Experienced User
I would look at some KB articles and see if these can help you out:
xSigoff wrote:
I cannot connect by remote desktop on my local gigabitcopper lan. no ports are visible locally, I cannot ping locally. How do I open up all ports on the local lan? I tried adding 3389 as as a custom port, but It will not allow that. any suggestions? In addition the discussion model entry (above) does not allow my model: RAX70.
- nielsvdsJan 10, 2022Luminary
First step is also allowing remote desktop on your other computers: https://docs.microsoft.com/en-us/windows-server/remote/remote-desktop-services/clients/remote-desktop-allow-access
What security software is locally installed? That can also block ICMP. So it can be necessary that you need to open port 3389 (remote desktop) and ICMP in your local firewall. Did you change the firewall settings on your router?
