martinb0820
Mar 10, 2020Guide
RAX75 - Automatic channel selection disappeared on 5GHz
As an experiment, I changed the 5GHz channel from Automatic to a specific channel. I would like to restore the original setting, but now "Auto" no longer appears as an option in the Channel combo box...
- Mar 10, 2020
I know the 2.4ghz has an automatic channel selection/steering but I wasn't aware the 5ghz did. My RAX200 other netgear AX devices don't have auto for the 5ghz option.
Mar 10, 2020Guru - Experienced User
- martinb0820Mar 10, 2020Guide
Hi plemans, thanks for the reply. I'm almost certain that there was an Auto option, but:
1. I'm confused (it wouldn't be the first time!) OR
2. There is an "anomaly" in that firmware version, and Auto shouldn't have appeared in the first place.
In any case, the channel that the router was originally on was also in use by someone else, so the current setup is an improvement...
Thanks again.
Sorry, meant to mark your message as the solution, got mine instead.
