ik8sqi
Jun 14, 2020Star
RAX75 1.0.3.88 firmware broke HomeKit
I've been using my Nighthawk RAX75 (the Cosco version of the RAX80) for several months, configured with SmartConnect without any major issues with HomeKit. A few days ago almost all of my 40+ Hom...
MacauBBS
Jun 18, 2020Star
The SmartConnect problem has always been there,
Manually set the 2.4G/5G SSID to be the same, the effect is better.
ik8sqi
Jun 18, 2020Star
MacauBBS wrote:The SmartConnect problem has always been there,
That is incorrect - SmartConnect has worked just fine with HomeKit on my RAX75 for over 6 months when using the older firmware.
I previously tried two differe routers - the TP-Link Archer AX6000 and the ASUS ROG Rapture AC5300, and both had issues with their version of SmartConnect and HomeKit. I then switched to the Nighthawk, and had no issues with it for months, until Netgear released this new 1.0.3.88 firmware.
- ik8sqiSep 10, 2020Star
For the record, firmware 1.0.3.102_1.0.48 has severl fxes, but not one for Homekit. Most of my homekit devices became unresponsive within a few hours after upgrading from 1.0.2.76 to 1.0.3.102_1.0.48.
Unbelievable that Netgear is neither fixing this nor even acknowledging there's a problem. Knowing that Homekit worked in 1.0.2.76 and broke in 1.0.3.88 and higher should easily let them discover what code changes caused the issues...
- schumakuDec 09, 2020Guru - Experienced User
Christian_R action please.
- ik8sqiJan 10, 2021Star
Hasn't anyone at Netgear heard of "HomeKit"...? As an FYI V1.0.3.106_1.0.50 does not work eaither. HomeKit devices stop responding within 5 minutes of a router reboot when using SmartConnect.
- frenchcamp49erApr 15, 2021Star
So was this issued ever solved?
