ik8sqi
Jun 14, 2020Star
RAX75 1.0.3.88 firmware broke HomeKit
I've been using my Nighthawk RAX75 (the Cosco version of the RAX80) for several months, configured with SmartConnect without any major issues with HomeKit. A few days ago almost all of my 40+ Hom...
frenchcamp49er
Apr 15, 2021Star
So was this issued ever solved?
ik8sqi
Apr 16, 2021Star
No - Netgear still did not fix the issue in the current firmware v1.0.3.106_1.0.50.
If you want to use HomeKit and all the router's security patches installed, you will have to disable one of the best advertised features of the router - smartconnect. The only way to have HomeKit work is to disable smartconnect so you have two separate SSIDs for the two bands, and then configure all your HomeKit devices to use the 2GHz band as several of them are unlikely to support the 5GHz one.
- frenchcamp49erApr 20, 2021Star
Thanks, thats the way I have it setup now anyway. So as long as disable smartconnect and name the bands differnt I shoulmd be good, correct?
