raymon_lee
Apr 16, 2020Aspirant
RAX75 5GHz wifi channel selection only 20MHz channel can be to select
RAX75 5GHz wifi channel selection only 20Hz channel can be to select it
At the set up 5GHz wifi channel only show the channel all is 20MHz
How to set and select to 40MHz or 80MHz or 160MHz
Firmware Version V1.0.2.76_1.0.35
1 Reply
What mode do you have it set to in wireless?
And what makes you think its only doing 20hz channel width?
to be able to tell, you'd need to install a channel scanner that shows wireless channel width. I think inssider and acrylic wifi analyzer both do it.
Here's how mines setup and its running 160hz wide channels
