Benjamin123
Dec 29, 2021Aspirant
RAX75 AX8 iphone/iPad not able to access router settings by searching router ip in search browser
Hello all, thank you in advance for your help. I’ve been trying for DAYS to access my router settings via my iPhone 12 or iPad Pro (while connected to my wifi network of course) with no luck. Those a...
Dec 29, 2021Guru - Experienced User
Can you access the routers web page with a wired or wireless connected PC or laptop and web browser?
Can you access the router by using the Nighthawk app?
Be sure you are connected to the routers wifi signal.
Try a different browser on the iphone, Firefox or Opera.
I can access my Orbi system and RAXE500 in bridge mode web pages on my iphone 12 max iOS 15 loaded currently.
Benjamin123
Hey FURRYe38!
I have not tried accessing the router web page with a computer of any kind yet. I currently only own an iPad and iPhone. The router nighthawk app does work on my phone and iPad but I’m needing to access more advanced features then what the nighthawk app can provide. Like firewall and port forwarding.
And yes, I am connected to the Wi-Fi’s signal.
The browsers I’ve tried so far are chrome, Firefox and safari with no luck.
- FURRYe38Dec 30, 2021Guru - Experienced User
What iOS version are you using on the Apple devices?
- nielsvdsJan 01, 2022Luminary
Try to disable Wi-Fi Assist to be 100% sure that you aren't using your mobile connection instead of Wi-Fi see here how to do that: https://support.apple.com/en-us/HT205296
- Benjamin123Jan 01, 2022AspirantHey nielsvds,
Thanks for helping, I just tried it with no luck unfortunately.
- Benjamin123Jan 01, 2022AspirantHi FURRYe38,
I’m currently using iOS 15.2 on both devices
