neverest5
Jun 02, 2020Follower
RAX75 firmware update not working
I just purchased the RAX75 from Costco and am running into issues both automatically and manually updating the router firmware. Here's the setup: - RAX75 on AP mode behind a Linksys SOHO route...
Christian_R
Jun 05, 2020NETGEAR Employee Retired
Hello neverest5,
Can you confirm you are using the following download link located at the bottom of this article. You may also try using the Nighthawk app to check for a firmware update.
https://kb.netgear.com/000061901/RAX75-Firmware-Version-1-0-3-88
Christian
