Xiiibc
Apr 02, 2020Aspirant
RAX75 issues
THis router has been a pain. The intitial install needed to be reset before my 5g band even started working. I called tech support for that. Then i woke up and i had internet over wifi on my iPhone, ...
Xiiibc
Apr 04, 2020Aspirant
As I mentioned in the starting article, I updated to 1.0.2.76 already and that changed nothing. What did help was taking that pile of trash back to costco and getting the MR60 meshed system. The MR60 worked right away and ive had no problems with it other than it is technically slower than the rax75. It still is an AX wifi 6 router, and covers a wider range with the satellite units.
The RAX75 is the first netgear router that i will publically call trash. Ive used many netgears over the years and this is the first i absolutely hated.
So leasons learned here: get the MR60 mesh nighthawk router, not the RAX75.
Xiiibc
note, i didnt mention i updated to 1.0.2.76. Allthough i did manage to make that happen after i posted this.
