PhillipJ
Apr 22, 2020Aspirant
RAX75 keeps disconnecting the 5GHZ after and before firmware 1.02.76
Went through tech to reconfigure and updated firmware 1.02.76 on 4-21-2020. I connect with the 5G and it disconnects every 2-3 hours and then comes back on itself. I have a Xfinity networks.. Before ...
Christian_R
Apr 23, 2020NETGEAR Employee Retired
Hello PhillipJ,
May you try disabling AX mode. Has support been able to follow up on your case?
Christian
PhillipJ
Apr 23, 2020Aspirant
If I disable this feature then what is the point of paying so much to get this router?? Doesn't make sense.. will it make this router then unable to reach my 2nd floor or limited the distance it can reach?? Please advise.
