MontanaMike's avatar
MontanaMike
RAX75 Latest Firmware April 2020
Good evening.  New to Netgear equipment and I have a question related to firmware.  No firmware is available to upgrade to from within the admin section of the RAX75/AX5700 (says I'm running: Firmwar...
  • microchip8's avatar
    Apr 12, 2020
    This happens frequently with NETGEAR. Sometimes they either forget to push the new version to the update server or are too late in doing it but it's up on the site before that. Sometimes a version gets pulled back quickly too because of issues. I suggest you download it and manually flash it and do a factory reset & reconfigure from scratch
