ronrad
Jun 02, 2021Tutor
RAX75 port forwarding not deleting successfully
NOTE: I chose the closest model it would let me. I believe this one was actually from costco. It's an RAX75 AX5700 according to the back of the device. I had configured port forwarding for 3...
ronrad
Jun 03, 2021Tutor
note also that through searches I have found that multiple people have reported the same root issue as far back as 2014 on multiple routers.
Here is an example:
The resolution always seems to be nuclear factory reset. (Which i used twice now and the issue returns within a few hours)
I am unable to contact actual customer suport without buying upgraded customer support for a product that is less than six months old. What a terrible customer experience.
Christian_R
Jun 07, 2021NETGEAR Employee Retired
Hello ronrad,
I'd like to assist with our support team reaching out to you. May you send me a private message with your email address and serial number.
Thanks,
Christian
- ronradJun 07, 2021TutorHi Christian pm being sent.
Thanks,
Ron
