gagandeep's avatar
Nov 23, 2019
RAX75, RAX80 or RAX120
Hi I have about 14 IoT devices on 2.4 GHz (smart swtiches, 1 printer, 3 Wifi Cameras on 720 so not too much data transfer load) that are serviced mainly by R7800 acting like AP. I also have 6 Laptops, Mobiles and iPads where moderate work is done via 5GHz. The 5GHz devices are serviced by AX88U Asus but I have seriously had it with the device having so many connectivity issues especially with my Wifi-6 enabled Note 10 Plus. I am planning to return AX88U and was wondering if I could go in for a good offer from on online retailer who is selling RAX75 for a good price? I am curious to know what is the difference between RAX75 and RAX80 - both have same specs when we do comparison on Netgear website? Also do they have a good coverage as compared to RAX120 which has more internal antennas? Range is of concern to me but RAX120 seems to be an overkill in my situation. Please advise! Thanks in advance!
  • Sorry please read the first sentence content as "......3 Wifi Cameras that have 720p resolution... so not too much data load"
    • GabboCH's avatar
      GabboCH
      Apprentice
      For now I would stay away from the Netgear Wifi6 devices.
      There are many issues with Wifi connectivity, slow transfer speeds & even problems with LAN connection speeds.
      Check out some of the threads at the top of the community relating to RAX80 or RAX120.
      These issues have been on-going for 6 months with not even acceptance from Netgear that they have problems so little chance of a firmware update coming soon to fix them.
      • GabboCH's avatar
        GabboCH
        Apprentice
        Given the relative price difference between a good Wifi5 and Wifi6 router I would recommend a good Wifi5 router for now.
        You are not the first here to mention problems with the Asus Wifi6 routers so given the number of problems with the Netgear equivelant as well it seems the problem is with the relatively new technology/chipsets rather than a problem specific to a certain supplier.
        I paid €350 for the RAX80 and have had >3 months with daily issues with connection, dial-up-modem like Wifi speed etc.
        I replaced the router with a €89 Wifi5 Triband extender (also from netgear the S6X/EX8000) and everything works correctly.
        I dont own any Wifi6 capable devices but have a large number of IoT devices, sonos, cameras, TVs, phones, tablets so expected the new router to handle a large number of connections better without compromising the network performance like Wifi5.
        At the moment I see an investment in Wifi6 as a "pre-order", expect lots of beta testing and frustration.....
