BuggyRAX75
Jan 28, 2025Aspirant
RAX75 shows dates 900k+ years in the future in logs
My RAX75 that has the latest firmware and shows dates of 900k+ years in the future when it drops wifi and the UI becomes very slow. The wifi radios drop randomly and sometimes do not recover full...
BuggyRAX75
I will factory reset it and see if that does anything.
The browser used to view the log should not change the log screenshot.
Jan 28, 2025Guru - Experienced User
Check other browsers to be sure.
How was the FW updated on the router, auto update or manually?
- BuggyRAX75Jan 28, 2025Aspirant
No change with other browsers.
Firmware was added initially through the UI over a year ago. Today I downloaded the latest firmware zip file today as well and re-applied it over the top. https://kb.netgear.com/000065067/RAX75-Firmware-Version-1-0-10-140
This 2022 era firmware should get updated as that is said to be the latest.
- FURRYe38Jan 28, 2025Guru - Experienced User
Ya, something NG will need to check into.
Other than this, does the router work otherwise?
Everything works until it drops wifi randomly and goes into this strange state, getting into the admin interface while this is occurring when wifi comes up you see these invalid dates being logged as I captured in the screen shot above.
Sometimes the wifi drops and the only way to recover is a hard reset which wipes the logs.
