xgx13xgx
Aug 25, 2023Aspirant
RAX75 to be used as slave in mesh system
I currently have a RAX75 router and will be upgrading to a mesh system and i had a thought. I have alot of home automation connected devices security cameras, stove, washer and dryer door locks garag...
Aug 25, 2023Guru - Experienced User
The RAX series doesn't support any MESH configurations or connections. RAX work independently of MESH systems. RAX series routers only support router, AP or for some, wireless bridge mode. Consult the user manual for modes that are officially supported by your model router. Or check the Routers web page under Advanced Settings to see which modes are actually supported.
