xgx13xgx
Aug 25, 2023Aspirant
RAX75 to be used as slave in mesh system
I currently have a RAX75 router and will be upgrading to a mesh system and i had a thought. I have alot of home automation connected devices security cameras, stove, washer and dryer door locks garag...
Aug 25, 2023Guru - Experienced User
What I'd do?
Setup your mesh system and connect the RAX to it with the RAX in access point mode. And use a different ssid for it. Also make sure the wireless channels are different from the mesh system.
Then you can put your IoT devices on the RAX and leave the mesh for the higher bandwidth devices.
I do something similar at times in my own home.
Kitsap
Aug 25, 2023Master
The RAX75, configured in access point mode, would connect back to your mesh system router via Ethernet cable. The RAX75 would be centrally located distance wise to feed your iOT devices. The configuration would work well and keep your iOT devices away from your mesh network.
Like plemans says, give the Wi-Fi from your RAX75 a different SSIDs and set the channels to something different from your mesh system.
