s83569
Jul 19, 2022Aspirant
RAX75, which I've bought recently on Ebay as used, fully working
Have exactly the same issue on my RAX75, which I've bought recently on Ebay as used, fully working.
2.4Ghz channel is working fine, but 5ghz network is not broadcasted at all, tried multiple scanne...
Jul 19, 2022Guru - Experienced User
1. what firmware are you on?
2. if it was used, did you try a factory reset?
3. you've disabled smart connect and set the 5ghz as a separate ssid?
4. what device are you scanning for 5ghz with and what scanner are you using?
- s83569Jul 19, 2022Aspirant1) the last firmware 1.140 and the initial one .58 were tested - same negative result
2) sure, multiple times even including 30-30-30 method.
3) yes
4) xiaomi mi8 and 2 laptops (one of them is 2021 model and works fine on wifi 6 for RAX38V2 which I've purchased just a couple days before RAX75.
