MrNunez
Jan 11, 2023Aspirant
RAX78 AP Mode - Disable DHCP?
I am using my RAX78 in AP mode and I need to disable DHCP. Everything seems to be working fine but I'm told that I should disable (true?). The LAN SETUP option is greyed out under ADVANCED > SETUP > LAN Setup. Does having my router in AP mode automatically disable DHCP or do I need to take me router out of AP Mode, disable DHCP, and then put it back in AP Mode?
I am connected to a CAX30 with Wi-Fi disabled.... THANK YOU!
MrNunez wrote:I am using my RAX78 in AP mode and I need to disable DHCP. Everything seems to be working fine but I'm told that I should disable (true?). The LAN SETUP option is greyed out under ADVANCED > SETUP > LAN Setup. Does having my router in AP mode automatically disable DHCP or do I need to take me router out of AP Mode, disable DHCP, and then put it back in AP Mode?
Yes, in AP mode, DHCP is disabled. With your configuration, the CAX30 is performing the routing functions for your LAN.
- KitsapMaster
