EZK2517
Jun 05, 2021Aspirant
RAX78 drops internet signal with USB connected
I have an RAX78 (they wouldnt let me select that so i picked teh RAX80 on teh dropdown) and that im trying to connect to a Seagate Backup Plus 5TB portable HD. whenever I do so, it drops the interne...
michaelkenward
Jun 06, 2021Guru - Experienced User
EZK2517 wrote:
....im trying to connect to a Seagate Backup Plus 5TB portable HD.
5 TB is bigger than most people have successfully deployed with ReadySHARE. 4TB seems to be top whack for most routers.
This list will give you some clues, although it is far from comprehensive:
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
In some cases this is because people are posting in the wrong section of this place.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
- Ezekiel2517Jun 06, 2021AspirantThanks. I have less than 3TB on it now. I wonder if I formatted it into smaller drives if it would see them or just see the first on or just not work at all. The latter seems to be the go to answer for this thing
- michaelkenwardJun 06, 2021Guru - Experienced User
I have no idea what ReadySHARE would make of a USB formatted drive like that, or even if that would case any of the "internet signal" drops that you experience. I just wanted to warn that larger drives can cause problems.
Looking at the latest list of USB drives, I see that it now has one larger drive (Seagate USB3.0 8TB Model:SRD0PV1) in there, but the list is so thin that it is anyone's guess as to what will work.
Will my USB drive work with ReadySHARE | Answer | NETGEAR Support
- Ezekiel2517Jun 06, 2021AspirantAgreed. They have very little data and even less data on AX routers.
