Aldirouter5369
Mar 03, 2021Aspirant
RAX78 Router and MR60 compatibility
Hi - first post here. I have an MR60 Mesh router system with 2 satellites that I bought to increase coverage in my house. This system works fine. I am currently in the process of changing my Veriz...
schumaku
Mar 03, 2021Guru - Experienced User
Ok, RAX78 is the router model - AX6200 is just a WiFi and sum-of-max-link-rate marketing speed.
The Nighthawk App can either manage the device where the mobile device with the App is currently connected to, or any other which must be configured for Anywhere Access. So you have to change the connection to the MR60/MS60 Mesh system. There is a home icon (on the Android App it's top left), from there you can change the managed system.
It's always possible to use a Web browser for the administration, I would suggest to start with the primary device, I guess this would be the RAX78. On this device you should be able to find the IP address of the MR60 which is still in AP mode one would guess under the attached devices. Voilà, use a second browser session and you have management admin access to both devices.
Aldirouter5369
Hi - Thanks for the quick reply I will try the suggestions you outlined in your response
