Louisville502
Jan 17, 2020Follower
RAX8 Router Wifi 0.8 mbps
So i have 400mbps Internet in a 1850 sqft open floor plan house. My cell phone is Wifi6 capable as well as my PC. i have a ring camera on the outside of my home. The RAX80 is for a 2500sqft home, ...
duckware
Jan 17, 2020Prodigy
Is your router on the latest firmware? If not, note the current version number (in case you need to revert), and upgrade?
Next, from a problem device, what PHY speed are you seeing on that device? See duckware.com/wifi#PHY
From PC/ethernet, what are the results of pinging the ring cam with "ping -l 62500 CAMIPADDDRESS"? (step two at duckware.com/ring#troubleshooting)
duckware
Jan 17, 2020Prodigy
And for testing only, what happens to speeds when you uncheck "Enable AX" under the wireless settings?
