daveychainsaw
Sep 08, 2020Aspirant
Rax80 - how to set to accept a WAN IP address dynamically
Hello, I'm about to change to FTTP using Gigaclear in the UK. They've advised that I can use my own router but to make sure that it is "running on IPV4 can accept the WAN IP address dynamically a...
Christian_R
Sep 11, 2020NETGEAR Employee Retired
Hi Dave,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
http://www.netgear.com/support/contact.aspx
Christian
daveychainsaw
Sep 13, 2020Aspirant
Nope, it's outside of the 90 days period, that's why i'm posting here. Doesn't look like I'm going to get any answers though.
I chatted with the ISP, they said it's best to ask Netgear. But I can't do that can I?
But they did suggest that it might be called DHCP mode. I've had a look in the router settings and that is enabled so hopefully it will be fine.
