Nmouneimne
May 06, 2020Apprentice
RAX80 - Problem with Readyshare Large File Transfer
I am getting Errir 0x8007003B Unexpected Network Error when I try to transfer large files from any Window10 PC to my USB harddrive connected to the router. Anyone else have the same issue? Netgear ph...
- May 07, 2020
I had the same problem,
so I downgraded to V1.0.1.64_1.0.27 and the problem was solved
If you need it, I will keep it and share it with you
https://drive.google.com/open?id=1eIDxDmEQO_vLj2tzufMzEhnJuuPtUiAo
MacauBBS
May 07, 2020Star
Nmouneimne
May 07, 2020Apprentice
Thank you! I will give that a try tonight and report back later. I can only really do these things once the family is asleep.
