Khublal
Apr 29, 2020Follower
RAX80 - ROUTER SPEED IS MUCH HIGHER THAT WIRELESS SPEEDS OR WIRED SPEEDS
Hello, I have 100 Mbps download and 10 Mbps upload speed from my IP I have tested the speed on the router directly and it reads 99 Mbps, however all my wired products are reading 28 to 29 M...
Apr 30, 2020Guru - Experienced User
What modem/gateway is it connected to?
What firmware are you on?
Have you tried a simple factory reset and reinstall? The RAX devices are pretty new and got a lot of firmware changes. Sometimes a simple reset/reinstall fixes a lot of issue with these devices.
