Samwin
Jul 20, 2020Aspirant
RAX80 - Slow Upload Speeds
Hi Guys, Bought the RAX80 about 3 weeks ago. The download speeds are fine but the upload speeds are giving me trouble. I am located in Canada, GTA area. Internet connection with Bell. Its a gigab...
Samwin
To add, I haven't made any change to default router settings and QoS is disabled.
- plemansJul 21, 2020Guru - Experienced User
what modem/gateway is it connected to?
are you using ipv4 or ipv6?
since you owned the rax200, have you tried a simple factory reset and reinstall? There was significant firmware changes with it and its responded favorably to factory resets after firmware changes.
- SamwinJul 21, 2020Aspirant
- It is a Bell homehub 2000
- ipv4
- RAX80 not 200. I did try factory reset yesterday. held reset for 10 seconds and configured router from the start. No change though. Just the upload speed is the issue. 0.10-0.20 mbps is ridiculous. Can't figure out why router would stop the upload speed. Direct connection to modem gives proper upload speed.
My bad. had rax200 in my head from a different post.
one thing. The home hub 2000 is a modem/router combo device. Is it configured in passthrough/modem only mode?
Or if you've left it in router mode, tried the RAX in access point mode?
Otherwise you're in a double nat.
