Samwin
Jul 20, 2020Aspirant
RAX80 - Slow Upload Speeds
Hi Guys, Bought the RAX80 about 3 weeks ago. The download speeds are fine but the upload speeds are giving me trouble. I am located in Canada, GTA area. Internet connection with Bell. Its a gigab...
Samwin
To add, I haven't made any change to default router settings and QoS is disabled.
Jul 21, 2020Guru - Experienced User
what modem/gateway is it connected to?
are you using ipv4 or ipv6?
since you owned the rax200, have you tried a simple factory reset and reinstall? There was significant firmware changes with it and its responded favorably to factory resets after firmware changes.
- SamwinJul 21, 2020Aspirant
- It is a Bell homehub 2000
- ipv4
- RAX80 not 200. I did try factory reset yesterday. held reset for 10 seconds and configured router from the start. No change though. Just the upload speed is the issue. 0.10-0.20 mbps is ridiculous. Can't figure out why router would stop the upload speed. Direct connection to modem gives proper upload speed.
- plemansJul 21, 2020Guru - Experienced User
My bad. had rax200 in my head from a different post.
one thing. The home hub 2000 is a modem/router combo device. Is it configured in passthrough/modem only mode?
Or if you've left it in router mode, tried the RAX in access point mode?
Otherwise you're in a double nat.
Enabled DMZ and selected my router as the device. Found online this is how you enable modem only mode. Didn't see any difference though. Still getting 0.1 Mbps speed.
