bayarnd
Dec 26, 2019Star
RAX80 / RAX75 Firmware 1.0.1.70 Problem
Nighthawk AX8 (RAX75) After updating from Firmware 1.0.1.64 to Firmware 1.0.1.70, I cannot run an admin connection from wireless clients to the router anymore, neither to 192.168.1.1. nor routerlogi...
MacauBBS
Feb 25, 2020Star
bayarnd wrote:Nighthawk AX8 (RAX75)
After updating from Firmware 1.0.1.64 to Firmware 1.0.1.70, I cannot run an admin connection from wireless clients to the router anymore, neither to 192.168.1.1. nor routerlogin.net.
Identical problem from iPad, iPhone and windows laptop, tested with Safari, Chrome, Firefox.
Hardwired clients can connect to the router as usual.
Chatted with support, downgraded to Firmware 1.0.1.64 and the connection works fine again.
Updated to Firmware 1.0.1.70 again plus reset to factory settings, the wireless connection stopped working again. Error is just "cannot connect to the server".
Is this a common problem with Firmware 1.0.1.70 - or does your wireless browser connection work okay after the update?
Thanks for your input..
My problem is that when you connect a USB hard disk,
it will be unstable,
such as: automatic restart or disconnection some time,
all without USB is normal.
bayarnd
Feb 25, 2020Star
I have the same issues with unstable USB disks.
I downgraded the router to the old Firmware 1.0.1.64 and it ran pretty stable for 7 weeks, including wireless admin access from my iOS devices and Readyshare sharing of 2 connected USB disks.
One week ago I updated again to Firmware 1.0.1.70 to see if there is a corrected release, but no success. The connected USB disks are visible for other network devices (shared via Readyshare) for a while, then they are gone. Rebooting the RAX75/80 brings the disks back for a while, until they are gone again.
Strangely, sometimes the disks are shared and visible in the network - but the router admin interface shows 'no usb disk' connected, no shared directories setup in 'readyshare'.
I will try to downgrade again to Firmware 1.0.1.64 and hope I can run this router in that configuration for maybe 6 months, and if there is no better new firmware release I may have replace it.
Thanks for the comments!
