bayarnd
Dec 26, 2019Star
RAX80 / RAX75 Firmware 1.0.1.70 Problem
Nighthawk AX8 (RAX75) After updating from Firmware 1.0.1.64 to Firmware 1.0.1.70, I cannot run an admin connection from wireless clients to the router anymore, neither to 192.168.1.1. nor routerlogi...
bayarnd
Mar 20, 2020Star
The support website still shows 1.0.1.70 as the current firmware version for the RAX75/AX8. Are you sure there is a newer one available?
FredAloneForEve
Mar 20, 2020Star
Yes here in France I have this new one.
See related and dedicated post
- SAM_the_GAMMar 20, 2020Luminary
I think the new firmware is regional I am in the USA in Los Angeles, CA and there is no new firmware found in the gui. The latest is 1.0.1.70
- LeoDaDiDitApr 02, 2020Aspirant
Router shuts off wireless access every 24 to 36 hours after upgrade to 1.0.70.1. Rebooting the router so far re-enables wireless service. I can do this either via power reset or can access to router remotely using cell service and the Nighthawk app from phone.
Leo
- SAM_the_GAMApr 02, 2020Luminary
The latest firmware for RAX75/80 is 1.0.2.76 http://www.downloads.netgear.com/files/GDC/RAX75/RAX75-V1.0.2.76_1.0.35.zip
- michaelkenwardApr 03, 2020Guru - Experienced User
You have joined in on an existing conversation that may or may not have anything to do with your problems. You aren't even using the same hardware, according to your footer.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.You talk of a "power reset". If you mean power recycling (on/off), then a proper reset might be in order.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.If you need more help, you might get better and quicker replies, and find other answers, over in the appropriate section for the R8000:
Nighthawk WiFi Routers
