SweetDrinker
Aug 08, 2020Tutor
RAX80 1.0.3.98_1.0.46 firmware reseting after restart / loss of power.
I have been wanting to use my RAX80 in wirless AP mode and in doing so it needs to reboot to change. When it reboots it factory resets itself. No matter what i try if the RAX80 losses power it factor...
QKing
Sep 03, 2020Aspirant
Christian_R wrote:Hello,
May you revert to the previous firmware version and let me know if your issue persists.
https://kb.netgear.com/000061902/RAX80-Firmware-Version-1-0-3-88
Christian
I have similar issue, but on V1.0.3.92_1.0.43
Whenever you lose power, the only way to get the router to boot is to press and hold the reset button while booting. Otherwise it will just sit there and not boot, with fans spinning fast. I am scared of losing power, because every single time I have to manually apply settings.
Reaaaaaaallly want a firmware that can 1) boot reliably 2) can save settings
Christian_R
Sep 09, 2020NETGEAR Employee Retired
Hi QKing - We recently released a new firmware version for the RAX80. Please update to the latest version.
https://kb.netgear.com/000062282/RAX80-Firmware-Version-1-0-3-102
Christian
