Daven64
Oct 17, 2021Aspirant
RAX80-100NAS Unable to get firmware to updrade
I open the router control pannel, it says upgrade available. I say yes and it trys to update language table but just sits there flashing every 10 sec or so. Allowed it to run for 25 min and no chan...
- Oct 18, 2021
Thank you
After several trys I was able to get a manual update to work and the router now shows it is on the current firmware. Again my thanks
Oct 18, 2021Guru - Experienced User
Have you tried manually updating?
https://kb.netgear.com/23442/How-do-I-update-the-firmware-on-my-NETGEAR-router-with-a-web-browser
Daven64
Oct 18, 2021Aspirant
Thank you for the response.
Using the routerlogin.net sent me to Netgears web login page - so I used http://192.168.1.1 address, logged in and instead of just clicking the Upgrade available tab, I went into administration and tried to Update router. Same result as I reported earlier - just cycles approx every 10 sec flashing the 192.168.1.1 address in the lower left corner of the screen.
I did notice that the connection showed "unsecure" or unlocked in the web address window although it was by ethernet connection. Not sure that would make any difference.
- plemansOct 18, 2021Guru - Experienced User
That's why I said manually updating. You download the update yourself, extract it, and then manually upload it to your router.
- Daven64Oct 18, 2021Aspirant
Thank you
