Daven64
Oct 17, 2021Aspirant
RAX80-100NAS Unable to get firmware to updrade
I open the router control pannel, it says upgrade available. I say yes and it trys to update language table but just sits there flashing every 10 sec or so. Allowed it to run for 25 min and no chan...
- Oct 18, 2021
Thank you
After several trys I was able to get a manual update to work and the router now shows it is on the current firmware. Again my thanks
Daven64
Oct 18, 2021Aspirant
Thank you for the response.
Using the routerlogin.net sent me to Netgears web login page - so I used http://192.168.1.1 address, logged in and instead of just clicking the Upgrade available tab, I went into administration and tried to Update router. Same result as I reported earlier - just cycles approx every 10 sec flashing the 192.168.1.1 address in the lower left corner of the screen.
I did notice that the connection showed "unsecure" or unlocked in the web address window although it was by ethernet connection. Not sure that would make any difference.
Oct 18, 2021Guru - Experienced User
That's why I said manually updating. You download the update yourself, extract it, and then manually upload it to your router.
- Daven64Oct 18, 2021Aspirant
Thank you
