Daven64
Oct 17, 2021Aspirant
RAX80-100NAS Unable to get firmware to updrade
I open the router control pannel, it says upgrade available. I say yes and it trys to update language table but just sits there flashing every 10 sec or so. Allowed it to run for 25 min and no chan...
- Oct 18, 2021
Thank you
After several trys I was able to get a manual update to work and the router now shows it is on the current firmware. Again my thanks
Oct 18, 2021Guru - Experienced User
That's why I said manually updating. You download the update yourself, extract it, and then manually upload it to your router.
Daven64
Oct 18, 2021Aspirant
Thank you
