PDWhite
Feb 12, 2020Apprentice
RAX80 5 Ghz band... Bug preventing the 5Ghz band from running at full speed
After a long, diligent and frustrating effort to get Netgear Support to resolve a problem with my original RAX80, they finally sent a replacement. The new unit does not have the slowdown problem of the original. (And) Straight out of the box, the 5 Ghz band ran at the full, rated 4800 Mbps.
This is where problems started: I changed the 5 Ghz band's SSID from NETGEAR75-5G to my own The_Whites-5G. I hit apply and the resulting 5 Ghz band signal would not connect to anything. In fact, the 5 gig signal took minutes to come up and kept disappearing every few minutes from my Wi-Fi scanner. (WiFi Commander for PC, it's a great utility.)
Now, I know there was nothing exotic about my personal SSID, but I could only make a sucessful connection again if I backed the speed down to the "Up to 2400 Mbps" setting. Furthermore, attempting to use the original default SSID, NETGEAR75-5G made no difference. The only fix was to do a hard reset to original factory default.
Question: Has anyone else had this problem? Did you resolve it? Please RSVP with any comments... - Thanks!
have you tried setting the ssid up avoiding any special characters? Just letters/numbers?
Another thing is that the 4800mbps speed is dependant on using DFS channels. Is there a airport/base near you? If so, it could be auto switching off those dfs channels and that's why you're seeeing it disappear every few minutes.
- PDWhiteApprentice
Well, we don't have any airports near here. Also, I believe I'm using a channel that doesn't conflict with DFS frequencies.
The appearing/disappearing/not connecting problem only manifests itself when the speed is set as "up to 4800 Mbps." Setting for up to 2400 is a steady as a rock.
As far as I know, a standard SSID can be up to 32 8-bit bytes long. Apparently, the characters can be anything from NULLs on up. My hunch is that changing the SSID may actually 'burp' on some other configuration settings; possibly the ones governing the 5 Ghz band configuration. (And) since there is no code available setting to un-break the error, that is why only a hard reset or doing a restore to a good working configuration will fix the problem.
My conclusion is that it may be a bug in the configuration firmware, but if so, why aren't more people having the problem? I'm certain I'm not the only RAX80 owner that has changed the default SSID...
- owlpowerInitiate
I just got a RAX80 today, and I have been load testing it. I have had no connectivity issues at all with 15+ devices connected.
However, I noticed a detail in your post. I was getting inconsistent and very poor download speeds on 5GHz. They were always below 100 Mbps and sometime like half that amount. I set the Mode from 4800 down to 2400 Mbps and I am consistently getting way faster speeds on wireless download speeds.
Thanks!
