jfree427
Sep 01, 2020Aspirant
RAX80 5G signal is not broadcasting
My RAX80 has stopped broadcasting 5G for an unknown reason. I've done a factory reset. Loaded the latest firmware (V1.0.3.88_1.0.41) and tried various channels. Nothing has worked for me. Is anyone else having similar issues or can someone from Netlink support please chime in?
Thanks.
1 Reply
How do you know 5ghz isn't broadcasting?
What are the led's on it (the router) showing?
Are you using smart connect?
