kevin638880
Feb 13, 2020Follower
RAX80 abysmal WiFi Speeds
So I am from Hong Kong and the first major mistake I made in 2020 is that I didn't read through this forum before purchasing the RAX80. Otherwise I would have probably gone for the Asus RT-AX88U. M...
GabboCH
Feb 13, 2020Apprentice
As you already mentioned you have exactly the same issue as many people on here.
There is no issue according to Netgear, support will not help you & there is no firmware fix on the horizon.
The only solution is to throw it in the cupboard/bay/etc & buy something else.
Not sure if you have the 90days free support when buying in HongKong but it is worth a try to ask them to buy it back from you (one other user reported they accepted this).
However, in my experience the support is useless. The ask for lots of information, lots of log files but have no suggestions, solutions or feedback.... "lets try to take some more logs"...
