delta092
Dec 07, 2020Tutor
RAX80 Access Point Mode channels
I have a RAX80 with firmware V1.0.3.102_1.0.48 and running in AP mode (Canada Region). The 2.4ghz channel is set to auto and the 5ghz to channel 44. If I try to manually select different channels (e...
- Dec 07, 2020
Even if you select channel 40, its still broadcasting on channels 36-48 because its a 80hz wide spectrum. The RAX80 actually uses 160hz wide spectrum as well so if you have your speeds set for "up to 4800mbps" you'll actually be extending from channel 36-64. Its called channel overlap. I'll attach a diagram.
Benefit to 5ghz is that it doesn't broadcast as far or through as much materials. Plus since its so much faster than 2.4ghz, when it does broadcast, its for much shorter time periods. Its the reason it suffers from less interference and why you can have channel overlap without a whole lot of issues.
Dec 07, 2020Guru - Experienced User
