Jacek26
Jan 11, 2020Tutor
RAX80 and EAX80 separate ssids
So I have sold my orbi to a friend and went out and bought WiFi 6 netgear nighthawk but I also need a extender and thinking of getting the eax80 for $249.00 but I am worrying if I will have to tinke...
Jan 11, 2020Guru - Experienced User
It'll work either way. with seperate ssid or with the one ssid function.
i've got an honeywell smart thermostat and was able to set it up with orbi. I also got it working with my RAX200. If you've got it programed to a certain ssid/password, just keep it the same when you switch routers/extenders and it should auto-link to them.
