dml213
May 14, 2020Follower
RAX80 and fiber optics
Does the RAX80 WIFI router work with ATT fiber optics?
anshelsag
May 14, 2020Initiate
I have an RAX80 and have been running it for months on AT&T FIber, it works but you will have to use your AT&T Gateway as a modem only and tunnel to the RAX80.
Travis212
Aug 08, 2020Aspirant
Have you ever had connection issues that the only fix is to reboot the router. Every few weeks I have to reboot the router because nothing has internet access. When I check the ATT gateway, it says it has internet. The only fix, reboot the router
