MrCrypto
Jun 11, 2020Follower
RAX80 and netgear support
Why is netgear support so bad? I purchased two RAX80 Netgears for the first time and one of them has been either crashing or restarting probably weekly. I called after I was hoping a firmware update ...
Christian_R
Jun 17, 2020NETGEAR Employee Retired
Hello MrCrypto,
Has support been able to follow up on your case? If not, send me a private message with your case number(s) and email address.
Christian
Rozman
Jun 23, 2020Tutor
Christian,
Open 42897398
Closed 42944539, 42899523, 42897043,41375215
I see that you were intrested in this issue, well here is mine, and its the same.
I have enclosed all of my case numbers for the past 9 months. I also purchased the tech support tech package.
Nothing but problems and support that have no intrest in helping.
Please assist.
- Christian_RJun 23, 2020NETGEAR Employee Retired
Hi Rozman,
Thanks for reaching out. May you send me a private message with your email address and the current firmware version your router is on.
Thanks,
Christian
