Bendigo360
Jul 29, 2019Aspirant
RAX80 and R8000P Upload Issues
In June I bought an R8000P NightHawk router (AC4000). Here in my city we have a local internet provider that supplies 250mbps down and 250mbps for like $50 a month so natually I jumped on it. When I first got the router I was hitting the down and up speed easily. The NightHawk App was very accurate and it seemed to be going well. Over the course of the past 2 months I saw my speeds declining every day. Two weeks ago I reached out to my provider and they said that they would check my lines. I ran a spead test and I was getting about 80 down and 60 up. The came out and tweeked some things and did a fiber sweep and got the lines back where they are supposed to be. The tested my internet and I was getting 260mbps down and up, but when I plug my router in I am getting 260 down but only 80 up. The more I looked into it, the AC4000 seemed to have issues of going bad. So I returned it and got a RAX80. I brought it home and hooked it up and now I am still getting about 260 down and 80-100 up. What gives? I don't know why this is still an issue. The part that really gets me is the NightHawk app is now not showing more that 90 down and 70 up... But when I run it on my PC I am getting 250-260 down and 80 up? Anyone else have these issues?
- Netduma_AlexNetDuma Partner
Hi Bendigo360,
Could you please post about this in the following forum section: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
This section is just for the Nighthawk Pro Gaming Routers.
Thanks!
- Christian_RNETGEAR Employee Retired
Hello Bendigo360 - Thanks for your post. If you recently purchased your device, you are provided with 90 days of complimentary support. You may use the link below to get in contact with our Support Team.
https://www.netgear.com/support/default.aspx
~Christian
