funboy78
Dec 02, 2019Aspirant
RAX80 AP mode, internet not connected
Hello, I have configured my RAX80 in AP mode, everything works, I have internet access through Wifi and RJ45 but the router tells me "internet not connected". and therefore the search for updates a...
funboy78
Hi
Yes Wireless AP
my primary router is connected through WAN (yellow) port
I used the fixed ip because the dynamic IP was not working
I have the latest version of firmaware because I updated it manually
d_only1jay
May 10, 2020Tutor
I am not using the Internet port on the RAX80 so the NTP and firmware update features are NOT working.
Is there a way for the Internet port to be "manually" configured as a LAN port?
As I really don't want to use the so called Wizard to configure the RAX80 since it creates a 10.x.x.x LAN which is NOT desired.
