Retired_Member
Oct 01, 2020RAX80 AX6000 WiFi issue after reboot, manual WiFi Button and Solved
Hi Everyone, Thanks for your time to read me message, I purchased a Netgear WIFI 6 Smart Router model RAX80 AX6000. I have been followed the guide way to setup everything is fine, and the current...
Christian_R
Oct 08, 2020NETGEAR Employee Retired
Hi Jason,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Retired_Member
Oct 10, 2020Thanks Christian,
Yes I did purchased RAX80 recently but the issue has been solved by itself, only need to wait for a bit long time is possible to connect the WiFi signal, I am not sure is it normal or some kind issue on it, but it works well right now, if any question for future conversation that I would like to discuss with you again, appreciated for your help.
Jason.
