1cor1613
Mar 25, 2020Aspirant
RAX80 behind RAX200
I have 3 areas with soundproofing construction techniques implemented that cause enough interference that wireless does not penetrate well enough from one area to the next to be useful, but some weak ...
Mar 25, 2020Guru - Experienced User
I wouldn't go that route unless you didn't have an option. The RAX line aren't mesh setups.
If you want roaming options, look to the Orbi line of products. Plus you can add in satellites as needed for extra coverage.
1cor1613
Thanks, but I already have the gear described. Is there a way to make this work with these three RAX devices?
