1cor1613
Mar 25, 2020Aspirant
RAX80 behind RAX200
I have 3 areas with soundproofing construction techniques implemented that cause enough interference that wireless does not penetrate well enough from one area to the next to be useful, but some weak ...
windyconcrete
Aug 01, 2026Aspirant
Your thread came up for me 6+ years later with my own dealing with the RAX80. I am using it in the way you indicated here, but not in adjacent rooms. I have my RAX80 in a detached garage patched into my network via MOCA / coax arrangement. It works well. To get my setup I followed some stuff I found on topic online, probably like you. But what I wanted to mention here was use of Android phone apps to evaluate connection and signal strength. So I was using a little app called 'WiFiAnalyzer' and another called 'iPerf' and these would permit me to walk around my place looking at radio (SSID) strength for picking my channels (1st app) and then check gain / loss of signal on roaming basis (2nd app) once I had trial AP settings. Use of this required me to go into the Android using so-called 'developer options' and boost the wifi pinging rate (a battery drain) while I did all this. So a fair amount of hoops involved, but satisfying in the end, compared to buying the next overpriced thing from BestBuy. Here's my question for you -> now that the RAX80 is at end of service (patches, etc.) and it's not accessible to opensource projects like WRT due to the Broadcom chip, how do you plan to continue using these planned obsolescence devices? Are they working for you NOW as originally planned in 2020? If so, I would keep using them until they die. But I'm curious your plan. Cheers!
- 1cor1613Aug 01, 2026Aspirant
That looks like it probably worked well for you. I do use WifiAnalyzer but have not used iPerf; I will need to look into that. Unfortunately, I did not take the time to be as precise as you and took the lazy man approach. Since I placed the ethernet backhaul into the design of my soundproof basement and up to my other 2 floors, I have that to rely on. I replaced my RAX gear with a mesh system (asus ZenWifi 30000) and that solved for my needs. I think fine tuning signal strength would still provide benefits. I still have my RAX gear collecting dust on a shelf. It is good gear even now, but I should probably sell it off at some point.
